Jackie_
Referencing Box Plot outliers checkbox in Graph Builder
How can I reference the checkbox in the box plot option using jsl?
I tried the following but doesn't work. Any Suggestions?
checkboxes = nw << XPath("(//OutlineBox[text()='Plots']//OutlineBox[text()='Box Plot']//CheckBoxBox)");
checkboxes[N Items(checkboxes)] << Set All(0);
dt = Open( "$SAMPLE_DATA/Semiconductor Capability.jmp" );
List1 = {"NPN1", "PNP1", "PNP2", "NPN2", "PNP3", "IVP1"};
List2 = {"PNP4", "NPN3", "IVP2", "NPN4", "SIT1"};
List3 = {"INM1", "INM2", "VPM1", "VPM2", "VPM3"};
List4 = {"SNM1", "SPM1", "NPN5", "EP2", "ZD6"};
var expr1 = Expr( Variables() );
For( c = 1, c <= N Items( List1 ), c++,
	x expr1 = Expr(
		X( Position( 1 ), Combine( "Parallel Merged" ) )
	Insert Into( x expr1, List1[c], 1 );
	Insert Into( var expr1, Name Expr( x expr1 ) );
var expr2 = Expr( Variables() );
For( c = 1, c <= N Items( List2 ), c++,
	x expr2 = Expr(
	Insert Into( x expr2, List2[c], 1 );
	Insert Into( var expr2, Name Expr( x expr2 ) );
var expr3 = Expr( Variables() );
For( c = 1, c <= N Items( List3 ), c++,
	x expr3 = Expr(
	Insert Into( x expr3, List3[c], 1 );
	Insert Into( var expr3, Name Expr( x expr3 ) );
var expr4 = Expr( Variables() );
For( c = 1, c <= N Items( List4 ), c++,
	x expr4 = Expr(
	Insert Into( x expr4, List4[c], 1 );
	Insert Into( var expr4, Name Expr( x expr4 ) );
lists = {"List1", "List2", "List3", "List4"};
var = {};
gbv = {};
For( i = 1, i <= 4, i++,
	Insert Into( var, Name Expr( Eval( Parse( "var expr" || Char( i ) ) ) ) );
	Insert Into( gbv, Parse( "vvv" || Char( i ) ) );
nw = New Window( "Plots",
	Show Menu( 0 ),
	show toolbars( 0 ),
	H List Box(
		Check Box(
			{"Summary"},
			<<Set Function(
				Function( {self},
					sel = self << get selected();
					If( N Items( sel ) > 0,
						For( i = 1, i <= N Items( lists ), i++,
							If( N Items( Eval( Parse( lists[i] ) ) ) > 0,
								nw[lists[i], Outline Box( 1 )] << append(
									V Scroll Box(
										size( 580 ),
										Border Box( Left( 5 ), Right( 5 ), Top( 5 ), Bottom( 5 ), Sides( 15 ),
											Tabulate(
												Show Control Panel( 0 ),
												Set Format( Uniform Format( 10, 2 ) ),
												Add Table(
													Column Table( Statistics( Mean, Std Dev ) ),
													Row Table(
														Analysis Columns(
													Dispatch( {}, "Tabulate", OutlineBox, {Set Title( "Summary Stats" )} )
								) << Visibility( "Visible" );
					/// Xpath syntax
	nw << XPath( "//Outlinebox[@helpKey = 'Summary Stats']" ) << delete;
		V List Box( tb = Tab Box() )
	tb << Add(
		lists[i],
		V List Box(
			H List Box(
				Eval(
					Eval Expr(
						gb = dt << Graph Builder(
							Size( 1117, 781 ),
							Expr( Name Expr( var[i] ) ),
							Elements(
								Histogram(
									X( 1 ),
									X( 2 ),
									X( 3 ),
									X( 4 ),
									X( 5 ),
									X( 6 ),
									X( 7 ),
									X( 8 ),
									X( 9 ),
									X( 10 ),
									X( 11 ),
									X( 12 ),
									X( 13 ),
									X( 14 ),
									X( 15 ),
									X( 16 ),
									Legend( 2 ),
								Box Plot(
									X( 1 ),
									X( 2 ),
									X( 3 ),
									X( 4 ),
									X( 5 ),
									X( 6 ),
									X( 7 ),
									X( 8 ),
									X( 9 ),
									X( 10 ),
									X( 11 ),
									X( 12 ),
									X( 13 ),
									X( 14 ),
									X( 15 ),
									X( 16 ),
									Legend( 3 ),
									Outliers( 0 )
				sumsta = Outline Box(
					lists[i],
					<<visibility( "Collapse" )
Re: Referencing Box Plot outliers checkbox in Graph Builder
Use << Get XML to see what you are looking for
And then use pure XPath or combine it with other ways of getting references
(((nw << XPath("//MouseBox/TextBox[text()='Outliers']")) << parent) << sib)
Edit:
With XPath you could use something like this or make it more robust
(nw << XPath("//MouseBox/TextBox[text()='Outliers']/../following-sibling::CheckBoxBox[1]"))
Edit:
Jackie_
Awesome! Thanks Jarmo
Jackie_
@jthi It works only for one tab. How could I reference all the checkboxes for all tabs?
Edit: NVM it works.
