Subscribe Bookmark RSS Feed
Reference to the Output Table Name
akash_nigam_gma
Jan 15, 2015
Hi I am trying to select a small subset of data from a big datatable and create a temporary table out of it. The overall objective is to  sumarize the subset data. The script below is creating the subset data table "Name" but it is not returning the reference to it for me to process the new table. In the script below it is summarize the data of Test data table but not the Name data table.
Please help me with it.
dt=Open("Test.jmp");
Z= NRow();
k=dt<< Get Rows Where(:Para == "THK" );
pt = dt << Subset(
Rows(k),
Output Table Name("Name"),
// I want to summarize the data from this subset  data table
Close (dt, No Save);
pt = Current Data Table ();
Summarize(
  a=by(:Para, Route),
  //b= by(:Route),
  c= count,
  meanHT = mean(SITE_VALUE),
  stdevHT = stddev(SITE_VALUE)
show (a,c);
ian_jmp
Jun 23, 2011
Perhaps the JSL equivalent of 'Tables > Summary' is better in this case?
NamesDefaultToHere(1);
rows2get = dt << getRowsWhere(:sex == "F");
dtSub = dt << Subset(Rows(rows2get), Output Table("Females"));
dtSummary = dtSub << Summary(Mean(:Weight), Group(:age));
akash_nigam_gma
Jan 15, 2015
Thanks. It seems to solve my original problem. .
Infact my original script also seems to work just does not allow me easy handling of datatable object. Like in the present case (using your script), I am not able to save the Subset Table. Any suggestions?? Thanks in advance
Close (dtSub, Save);
throws an error.....
I/O problem. Unable to open in ReadWrite mode.
The system cannot find the file specified.
Save changes to the JMP Data Table Female?
ian_jmp
Jun 23, 2011
If you use the 'Save' option of 'Close()', you need to tell JMP where to put the file:
Wait(3);
Close(dt, Save("$DESKTOP/"||(dt << getName)));
Jun 22, 2012
I might be missing something, but from the original question, the issue stated seemed to be the need to be able to reference the subsetted data table for the summarize function.  In JMP 12, there is an additional argument available to the summarize function.  You can add the data table as the first argument.  So all you would need to do is to change the summarize statement to:
Summarize(pt,
  a=by(:Para, Route),
  //b= by(:Route),
  c= count,
Another observation is that you were using a statement of:
pt = current data table();
What I believe you really wanted to do is to set the current data table to pk, by using:
current data table(pk);
Or am I completely misdirected?
