Share your ideas for the JMP Scripting Unsession at Discovery Summit by September 17th. We hope to see you there!
PNash
Recoding multiple columns not working
COLS = DEMAND << GET COLUMN NAMES;
FOR EACH ROW( FOR (I = 5, I <= N ITEMS(COLS), I++, IF(ISMISSING(COLS[I]), COLS[I]=0)));
I have 20+ columns that I need to recode from empty to 0.  I can't seem to get a loop to work, so I'm clearly missing something.  Can anyone help?
Re: Recoding multiple columns not working
I think you have to convert the character string representing the name to a column reference. You need to add empty [ ] so that JMP knows to index the row.
For Each Row(
	For( I = 5, I <= N Items( COLS ), I++,
		If( Is Missing( As Column( COLS[I] )[] ),
			As Column( COLS[I] )[][] = 0
For Each Row(
PNash
The only tweak I had to make to your code was
to
As Column( COLS[I] )[] = 0
 but it worked!  Thanks
Article Labels
