Subscribe Bookmark RSS Feed
Recoding Data
siwong1210
Mar 2, 2015
Hi All,
First time trying to write a script to simplify the iterative process of recoding. The general idea is to just drag the variable into it's respective dialog box and be able to recode (in the same column or into new columns) based on where you drag it into but having trouble getting past the second step of referencing the column list from the dialog boxes.
Current Data Table() << Begin Data Update;
Delete Symbols();
dt = Current Data Table();
//Load Dialog Boxes & Capture Variables
result = Column Dialog(
  A1 = ColList( "Missing Recode" ),
  B1 = ColList( "Top 1-2 Ranking" ),
  C1 = ColList( "Likert 5 Point Scale - Top 1" ),
  D1 = ColList( "Likert 7 Point Scale - Top 2" )
//Need to reference column list??
For Each Row(
//0-1 Recode
  If( Is Missing(result), result = 0 )
Current Data Table() << End Data Update;
markbailey
Jun 23, 2011
Solution
As you define the column dialog, a list will be returned when the user clicks the OK or Cancel button. You should examine the Button( 0 | 1 ) item to decide which happened and proceed or quit accordingly:
If( result]"Button"] == -1, Throw( "User cancelled" ) );
In this case, it is a list of four assignments. Remove the last item and evaluate the list:
Remove From( result ); Eval List( result );
Now each assignment is done. Use the individual variables to decide what to do:
If( N Items( A1 ),
  For Each Row(
    If( Is Missing( A1[] ), A1[] = 0 );
If( N Items( B1 ),
markbailey
Jun 23, 2011
Solution
If( N Items( A1 ),
  For Each Row(
If( N Items( B1 ),
siwong1210
Mar 2, 2015
Thanks Mark! This helps tremendously and also leads me to my next question. Take A1 for example, my idea was to recode all of the "." to "0". Would I need to be using match (basically referencing the script outputted by JMP when recoding) or am I still able to use the if statement in this case? Or I'm probably using Is Missing incorrectly?
