Recode doesn't write into new column
Gedan
Community Member
Jun 9, 2017
after I summarized some tables, i want to recode the column "Source Table" into a new column with more specific strings. So I change the "New Values" in the recode window to my liking and choose "New Column".
A new column called "Source Table" gets created, but it is not filled with the strings i set in "New Values".
If i do the same with any other column, it works suddenly.
Can someone tell me, what i am doing wrong here?
1 REPLY
Jeff_Perkinson
Community Manager
Jun 23, 2011
Unfortunately, I'm not able to come up with an idea of what might be going on based on your description.
Can you provide some more details?
  • How did you summarize these tables?
  • Can you send a screen shot of your recode dialog?
  • Could you post a sample data table that demonstrates the problem? Be sure to remove or disguise any proprietary data before posting.
-Jeff
