tom_abramov
Level V
Rearranging two platforms created with BY
Please see the image.
Left side is the regular sequence if I add Distribution with BY and then Variability with BY to a window.
Is there some way to get the sequence as is in the right side?
The solution have to be in JSL and without looping but with using BY option.
Thanks.
Re: Rearranging two platforms created with BY
Here is the script, rewritten to make the Platforms Live
Summarize( dt, groupBy = by( :sex ) );
NW = New Window( "The Output", vlb = V List Box() );
For( i = 1, i <= N Items( groupBy ), i++,
	vlb << append(
		Eval(
			Substitute(
					Expr(
						dis =
						Distribution(
							Continuous Distribution(
								Column( :height ),
								Quantiles( 0 ),
								Summary Statistics(
									0
								Horizontal Layout( 1 ),
								Vertical( 0 )
							where( :sex == __where__ )
						var =
						Variability Chart(
							Y( :height ),
							X( :age ),
							Std Dev Chart( 0 ),
				Expr( __where__ ), groupBy[i]
Here is a very simple script, showing one way to do this
names default to here(1);
dt = open("$SAMPLE_DATA/big class.jmp");
dis = Distribution(
	Continuous Distribution(invisible,
		Column( :height ),
		Quantiles( 0 ),
		Summary Statistics( 0 ),
		Vertical( 0 )
	by( :sex )
var = Variability Chart(invisible,
	Y( :height ),
	X( :age ),
	Std Dev Chart( 0 ),
	by(:sex)
new window("together",
	vlb=vlistbox()
vlb << append(report(dis[1])[OutlineBox(1)]);
vlb << append(report(var[1])[OutlineBox(1)]);
vlb << append(report(dis[2])[OutlineBox(1)]);
var << close window;
dis << close window;
tom_abramov
Level V
Thank you Jim.
1. I need the graphs "alive", not reports only.
2. If I have many groups, I need loop. I am looking for solution without looping.
Something during creation of the platforms may be...
	vlb << append(
		Eval(
			Substitute(
					Expr(
						dis =
						Distribution(
								Column( :height ),
								Quantiles( 0 ),
								Summary Statistics(
									0
								Vertical( 0 )
						var =
						Variability Chart(
							Y( :height ),
							X( :age ),
							Std Dev Chart( 0 ),
