BookmarkSubscribeRSS Feed
pmroz
Jun 23, 2011
Read one record from file?
Hello JMP JSL people,
Is there a way to read just the first line of a text file? I've developed a system that reads delimited columns from a .CSV file. Now the users want new fields added to the input files, and some fields are renamed. The system has to be able to handle files in the new format as well as the old one, and do it transparently. If I could read the first line that would be great, as that line contains the field names.
Thanks,
Peter
mpb
Jun 23, 2011
Re: Read one record from file?
Example follows. In the case of CSV data replace the End of Field Tab with Comma. I got this by using the interactive text import preview on the specified file and copied the Source script embedded in the resulting JMP file. I removed the specific reference to the number of columns to allow the script to work with any number of columns.
Open(
"C:\Program Files (x86)\SAS\JMP\9\Support Files English\Sample Import Data\Animals_L.txt",
Import Settings(
End Of Line( CRLF, CR, LF ),
End Of Field( Tab ),
Strip Quotes( 1 ),
Scan Whole File( 1 ),
Labels( 0 ),
Column Names Start( 1 ),
Data Starts( 1 ),
Lines To Read( 1 ),
Year Rule( "10-90" )
pmroz
Jun 23, 2011
I didn't see that "lines to read" parameter. Unfortunately that doesn't work for me. My file uses "|" as the delimiter. I get all data crammed into one column.
Here's my code:
surv_dataset = Open(
surv_file,
Import Settings(
End Of Field( Other( "|" ) ),
Strip Quotes( 1 ),
Labels( 1 ),
Data Starts( 1 ),
Lines To Read( 1 ),
But I notice if I include the columns statement it works correctly, even if the column names are wrong. So I'll go that route.
Thanks for your help.
mpb
Jun 23, 2011
I ran the following code against this text file and it seemed to work:
First|Second|Third|Fourth
1|2|3|4
11|22|33|44
Open(
my_file,
Import Settings(
Strip Quotes( 1 ),
Labels( 0 ),
Data Starts( 1 ),
Lines To Read( 1 ),
