BookmarkSubscribe
djhanson
Read in array from text file? Possible in JSL?
Does anyone know if JSL can read in an array from a text file? any help much appreciated... dj
For example:
array1 = Include("C:\myArray.txt");
where the myArray.txt file would contain in its first line of text: "apple","pear","orange"
so that JSL would eventually interpret:
array1 = {"apple","pear","orange"};
djhanson
Re: Read in array from text file? Possible in JSL? [solved]
After doing a little research I stumbled across the LoadTextFile command:). This solution below works great in case it helps others... So in this case I am able to store large arrays in a separate text file and read them directly into the JSL code. dj
array1 = parse(eval(LoadTextFile(eval()))); //where path is the text file's path+file name.txt which can be represented by a variable. In the text file I wrote the array exactly like this: {"apple","pear","orange"}
Message was edited by: djhanson
