BookmarkSubscribeRSS Feed
paolo_campiglio
Apr 8, 2015
Range around maximum
Sorry in advance for this newbie question:
I have simply one x and one y columns. With a script I am trying to get a table with:
  • the maximum y (no problem with this),
  • the average in a defined range around the maximum,
  • the x value corresponding to the maximum y.
Probably it is a very easy script, but I have not be able to progress on it!
Thank you for your help!
ian_jmp
Jun 23, 2011
Solution
Re: Range around maximum
Something like this would do. But note that 'LocMax()' returns the position of the first maximum, and if there are multiple maxima you will have to do more work. Also, if the window is truncated you may wish to adjust the calculation of the mean, depending on what you need.
NamesDefaultToHere(1);
// Make some data
dt = NewTable("X and Y",
  NewColumn("X", Numeric, Continuous, Formula(RandomNormal())),
  NewColumn("Y", Numeric, Continuous, Formula(RandomNormal())),
  AddRows(100)
// Get the data into vectors
xVals = Column(dt, "x") << getAsMatrix;
yVals = Column(dt, "y") << getAsMatrix;
// Find the position of the largest y value
yMaxPos = LocMax(yVals);
// Get the corresponding x and y values at this position
yMax = yVals[yMaxPos];
xMax = xVals[yMaxPos];
// Define window size (consisting of an odd number of values)
winSize = 9;
// Calculate the positions of the window's edges
left = yMaxPos - (winSize - 1)/2;
right = yMaxPos + (winSize - 1)/2;
// Make sure the edges are in range
if(left < 1, left = 1);
if(right > NRow(yVals), right = NRow(yVals));
// Calculate the average y value in the window
yMean = Mean(yVals[left::right]);
// Print to Log Window
ClearLog();
Print(yMaxPos, yMax, xMax, winSize, left, right, yMean);
ian_jmp
Jun 23, 2011
Solution
// Make some data
  AddRows(100)
winSize = 9;
ClearLog();
paolo_campiglio
Apr 8, 2015
That's perfect, thank you very much Ian for your exhaustive answer!
