Jaz
Jaz
Level V
RE: If Statement Evaluates for Both True & False
I  was wondering why in the following if statement both parts of the statement are executed when I run the script? It somehow evaluates the statement to both true and false.
For (k = 1, k <= N Rows(dx), k++,
	Current Data Table (dt);
	q = k-1;
	For Each Row(
		If(dt:colAutomatically <= colManuallyEnd[k] & dt:colAutomatically >= colManuallyStart[k], dt:newInstructionsColumn = colInstructions[k], print("No"));
If true it should execute the following line:
If false it should execute the following line:
print("No")
Any help would be appreciated.
Try using this code to check out what is going on
For( k = 1, k <= N Rows( dx ), k++,
	Current Data Table( dt );
	q = k - 1;
	For Each Row(
		If( dt:colAutomatically <= colManuallyEnd[k] & dt:colAutomatically >= colManuallyStart[k],
			dt:newInstructionsColumn = colInstructions[k];
			Print( "\!nYes ", Row(), " ", dt:newInstructionsColumn[Row()] );
			Print( "\!nNo ", Row() )
	q = k - 1;
	For Each Row(
pmroz
The line that might be causing trouble is this one:
If any of your variables are referencing other table columns (like the dx table) I'm not sure what the current data table will actually be.  It's safer to qualify all columns with the table that they're in.  For example where does colManuallyEnd point to?
colManuallyEnd[k]
I suspect that it's a column in the dx table.  Maybe safer to say
dx:colManuallyEnd[k]
If indeed there's a column called colManuallyEnd.
Otherwise put a bunch of print statements inside your loop as Jim suggested.
