bthaby1
Question on use of the local data filter
I like the local data filter function in that a few graphs can update as the filter is used.   This updating only applies to the underlying
main data table.     I was wondering if you could make a summary of this local data table, then  create a 3rd chart and have this 3rd chart
(expression A3) somehow also update when the filter is used. .   here is the example script.
Any ideas ?
Also where is this local data table hidden ?
varlist = {"height","weight"};
A1 = Expr(
  a1vc = dt << Variability Chart(
  Y( Eval( varlist[1] ) ),
  X( :name),
  Max Iter( 100 ),
  Conv Limit( 0.00000001 ),
  Number Integration Abscissas( 128 ),
  Number Function Evals( 65536 ),
  Analysis Type( Name( "Choose best analysis (EMS REML Bayesian)" ) ),
  Process Variation( 0 ),
  Show Points( 0 ),
  Std Dev Chart( 0 ),
  Dispatch(
  {"Variability Chart for height"},
  "Variability Chart",
  FrameBox,
  {Frame Size( 200, 180 )}
A2 = Expr(
  Y( Eval( varlist[2] ) ),
  X( :name ),
  Max Iter( 100 ),
  Show Points( 0 ),
  Std Dev Chart( 0 ),
  Dispatch(
  {"Variability Chart for weight"},
  FrameBox,
A3 = Expr(
  subdt = dt << Summary( Group( :age ), Mean( :height ), Mean( :weight ) );
  t1 = Control Chart(
  Sample Label( :age ),
  Group Size( 1 ),
  KSigma( 3 ),
  Chart Col( :Name( "Mean(height)" ), Individual Measurement )
  // I want to figure out how to get this graph using SUBDT to also
  // update when the data filter is used.
Load_Dashboard = Expr(
  dashb = New Window( "test",
  v1 = V List Box(
  Data Filter Context Box(
  H List Box(
  df = Current Data Table() << Data Filter(
  Add Filter(columns( :age , :sex),
  Display(:age, Blocks Display ),
  Display(:sex, Blocks Display ),
  Mode( Show( 1 ), Include( 1 ) ),
  Local ),  // local data filter
  Platform(Current Data Table(),Eval(a1)),
  Platform(Current Data Table(),Eval(a2)),
  Platform(Current Data Table(),Eval(a3)),
Eval(Load_Dashboard);
// set dashboard window position and size
dashb << Set Window Size( 2400, 3000 );
dashb << Move Window( 3, 3 );
dashb << reshow;
rdf = df << report;
