Can we use the following query
dt = Open("tablename");
r = dt << Get Rows Where(:testid in ('1','2'));
there are probably other ways, here's one:
r = dt << Get Rows Where( contains( {"F", "M" }, sex ) );
[1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23,
24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40]
JMP doesn't have an In() function the way SQL does.
You'll need to test each value individually, like this:
r = dt << Get Rows Where(:testid == '1' | :testid == '2');
-Jeff
If you have a lot of values to look for C Hales solution is the way to go. Works in a similar manner to a SQL IN list.
BTW when is JMP going to put SQL into the product???? PROC SQL has been in SAS for a long time now.
PMroz and Craige@JMP are right.
I misunderstood Craige@JMP's example.
Here's one that might be clearer.
dt=open("$SAMPLE_DATA\Big Class.jmp");
//get the rows for ages 13 and 17
age13and17=dt<<get rows where(contains({"13", "17"}, char(:age)));
//select those rows
dt<<select rows(age13and17);
-Jeff
Thanks Jeff, that does illuminate the example quite a bit.
