lucy_luo_conoco
Python Kernel Crashed while running JMP Formula Depot output python code (Random Forest Model)
I used Formul Depot to save one Random Forest Model as python code (BF_ISIP.py ) in the attached zip file. the size of py code is 25MB.
when I run in Python 3.6 or lower version,
import BF_ISIP.py crashed and could not run, and I could not use this prediction in python environment.  see the picture.
But when I run BF_ISIP.py in lynux under Python version 3.7, crash didn't happen. and I can get prediction no problem.
Anyone knows how to fix this kind of issue from Python 3.6 ? thanks!
ian_jmp
Re: Python Kernel Crashed while running JMP Formula Depot output python code (Random Forest Model)
It's certainly possible you will get an answer here. But, since this is a Python issue you might be better posting in an associated forum too.
lucy_luo_conoco
Ian,
thanks for your reply. I just wondering if I am the only one run into this kind of issue? someone is questioning my jmp-created-python code instead of python since python  3.7 published only several  months ago.
