frankeberle
Jun 2, 2016
Proper Syntax for Table Preferences
I have a script that appends data to a journal but I would like to color the table numbers based on the value.  I know there is away to color by doing the following:
Preferences(
Conditional Formatting Rules(
RuleSet(
RuleName( "Yield Check" ),
GreaterThan( Value( 70.0 ), Inclusive( 1 ), Format( Text Color( "Black" ), FontStyle( Bold ), Back Color( 73 ) ) ),
GreaterThan( Value( 85.0 ), Inclusive( 1 ), Format( Text Color( "Black" ), FontStyle( Bold ), Back Color( 4 ) ) ),
LessThan( Value( 70.0 ), Inclusive( 0 ), Format( Text Color( "Black" ), FontStyle( Bold ), Back Color( 3 ) ) )
The problem is that the script doesn't evaluate the second GreaterThan line. I know you can go into the prefeneces settings and edit the rule manually but I would like to do this in script.  I just want to know if there is a way to code in 70< x < 85 turns yellow.
Thanks for the help.
Jun 22, 2012
Solution
Re: Proper Syntax for Table Preferences
You can only have one Greater Than clause.  To handle your between group, you need to use a Range.  Here is an example:
Preferences(
		RuleSet(
			LessThan( Value( 70 ), Inclusive( 0 ), Format( Text Color( "Red" ), Back Color( "White" ) ) ),
			Range(
				MinValue( 70 ),
				MaxValue( 85 ),
				InclusiveStart( 1 ),
				InclusiveEnd( 0 ),
			GreaterThan(
				Value( 85 ),
				Inclusive( 0 ),
				Format( Text Color( "Medium Light Blue" ), Back Color( "White" ) )
The easy way to get the correct syntax for this, is to interactively create the conditional format, and then to run the code to retrieve the preference
a = Preferences[1] << Get(
	Conditional formatting rules
Show( a );
1 REPLY
Jun 22, 2012
Solution
Preferences(
		RuleSet(
			Range(
				MinValue( 70 ),
				MaxValue( 85 ),
				InclusiveEnd( 0 ),
			GreaterThan(
				Value( 85 ),
				Inclusive( 0 ),
Show( a );
