Stefan_Moser
Prompt user to save as project at end of workflow
Similar post here for files but this solution didn't work for the project: https://community.jmp.com/t5/Discussions/Prompting-user-to-Save-As-at-the-end-of-workflow/td-p/91457...
I'd like to prompt the user to save as a project since I have a workflow embedded in in a project for ease of use. Ideally the function is the same as if the user clicked File --> save project as. So a window pops up, they select a directory, and create a name for the project.
The JSL below currently returns the following error
proj = Current Data Table() << Get Project();
proj << Save As("");
This version runs without error but doesn't actually do anything:
proj << Save As();
hogi
Level XIII
Re: Prompt user to save as project at end of workflow
Is the current window  the project window?
Then
 can be implemented via
main menu("Save Project As")
hogi
Level XIII
Then
Stefan_Moser
Awesome yes @hogi it will always be the current window since the workflow is executed in that window.
