Programmatacally detecting an Axis Box Change
I have a need to match the Axis settings between a Oneway platform and a Bivariate platform.  While setting the initial values is without issue, what I need to be able to do, is to detect any interactive change in the axis of one of the two displays, and then apply the same axis change to the other graph.  That is, when someone changes the y axis settings on the Oneway graph, the script programmatically detects the change, and applys the new axis settings from the Oneway graph, to the y axis of the Bivariate chart.
Does anyone have a solution for this?
Jeff_Perkinson
Re: Programmatacally detecting an Axis Box Change
Try adding a graphics script that uses the Y Range() and Y Origin() functions (and their equivalents for the X axis).
-Jeff
-Jeff
Jeff_Perkinson
-Jeff
-Jeff
Your suggestion is spot on.....thanks
