soar73
Proctection of soure code with JMP ADD-IN file
Could JMP add-in file securely protect source code (JSL) ?
To do that, Should I 'enscript' script before creating ADD-IN file ?
Re: Proctection of soure code with JMP ADD-IN file
You are correct.....encode the script before adding it to the Addin
soar73
THANKS for quick answer !
