AsymptoticCos
Process many columns with for loop
I have 100 Character columns named Column_1, Column_2,....Column_100. Each column has entries like A1, A2, ... A100. I am trying to create 200 columns from these 100 columns where each input column will create 2 output columns one output column will have the letter (A) and the other column will have the number (1,2,...). How to write this?
Re: Process many columns with for loop
Here is an example
names default to here(1);
dt =
New Table( "Example",
	Add Rows( 20 ),
	New Column( "column 1",
		Character,
		Formula( "A" || Char( Random Integer( 1, 100 ) ) )
	New Column( "column 2",
		Character,
colList = dt << get column names( string );
For Each( {col}, colList,
	dt << New Column( col || " Letter",
		character,
		set each value( Substr( As Column( col ), 1, 1 ) )
	dt << New Column( col || " Number",
		set each value( Num( Substr( As Column( col ), 2 ) ) )
Or using a For() Loop
dt =
	Add Rows( 20 ),
		Character,
		Character,
For( i=1,i<= NItems(colList), i++,
	dt << New Column( colList[i] || " Letter",
		character,
		set each value( Substr( As Column( colList[i] ), 1, 1 ) )
	dt << New Column( colList[i] || " Number",
		set each value( Num( Substr( As Column( colList[i] ), 2 ) ) )
Here is an example
dt =
	Add Rows( 20 ),
		Character,
		Character,
		character,
dt =
	Add Rows( 20 ),
		Character,
		Character,
		character,
AsymptoticCos
I have other columns in the table as well. Say Column X, Column Y. I don't want these columns to be part of the processing. How do I change your line to only focus on the columns I care about.
remove from(colList,contains(colList,"Column X"),1);
Please take the time to read the material under the Help=>JMP Help Online  in the Scripting Guide section.  Also, familiarize yourself with the Scripting Index under the Help pull down menu.  These pieces of documentation will provide you with a good background on the Scripting Language and conventions in JMP.
