SpannerHead
Process Screening By Groups
I want to automate a Process Screening, whereby all grouped variables are included as Process Variables.
The Typical script I get for the Process Screening looks like this
Process Screening(
	Process Variables(
		Column Group( "ENG" ),
		Column Group( "REJ" )
	Grouping( :WAFER, :LOT ),
	Control Chart Type( "Indiv and MR" )
I am able to create a list of available groups but can't figure out how to add those to the Process Screening.
dt = Current Data Table();
Grps = dt << Get Column Groups Names;
ps = dt << Process Screening(
	Process Variables(Column Group( Expr(Grps) )),
	Grouping(:LOT, :WAFER),
	Control Chart Type("Indiv and MR"),
	Within Sigma(0),
	Overall Sigma(0),
	Stability Index(0),
	Mean(0),
	Show Tests(0),
	Test 1(0),
	Out of Spec Rate(0),
	Latest Out of Spec(0),
	Cpk(0),
	Ppk(0)
The script above chokes because it needs to iterate through each item in the list.
Slán
SpannerHead
Re: Process Screening By Groups
I tried a couple of methods, but had to revert back to an Eval(Parse()) method.....ugly but it works
Eval(
	Parse(
		"ps = dt << Process Screening(
	Process Variables(Column Group( \!"" || Grps[1] ||
	Control Chart Type(\!"Indiv and MR\!"),
	Within Sigma(0),
	Overall Sigma(0),
	Stability Index(0),
	Mean(0),
	Show Tests(0),
	Test 1(0),
	Cpk(0),
	Ppk(0)
Eval(
	Parse(
	Within Sigma(0),
	Overall Sigma(0),
	Stability Index(0),
	Mean(0),
	Show Tests(0),
	Test 1(0),
	Cpk(0),
	Ppk(0)
SpannerHead
I've seen uglier, I own a mirror.  Works well.  My underlying goal was to select only columns with specs applied which in my case means grouped columns.  I subsequently went at the problem in a different direction that also works.  I like your approach better.
colList = dt << get column names( numeric, string );
SpecCols = {};
For Each( {colnames, index}, colList,
	spec = Column( dt, colnames ) << get property( "Spec Limits" );
	If( !Is Empty( spec ),
		Insert Into( SpecCols, colnames )
	Process Variables( Eval( SpecCols ) ),
	Control Chart Type( "Indiv and MR" ),
	Within Sigma( 0 ),
	Overall Sigma( 0 ),
	Stability Index( 0 ),
	Mean( 0 ),
	Show Tests( 0 ),
	Test 1( 0 ),
	Out of Spec Rate( 0 ),
	Latest Out of Spec( 0 ),
	Cpk( 0 ),
	Ppk( 0 )
Slán
SpannerHead
