BookmarkSubscribe
tova
Community Trekker
Process Screen, 1 value per subset, how is within sigma calculated?
I have data that consists of groups of subgroups.  Each subgroup consists of one value.  When I run the process screening on it, I get an overall sigma (the sigma between the different subgroups) and a within sigma.  I cannot figure out what this within sigma is.  I would like to use the stability index in my analysis, but cannot figure out how it (or the stability ratio) is calculated.  Where does this within sigma come from/how is it calculated?
For some reason i can not upload the process screening or the data table.  I have them availableif they are necessary for answering my question.
Thanks,
Tova
vince_faller
Re: Process Screen, 1 value per subset, how is within sigma calculated?
Minimum subgroup size is two.  If you run.
names default to here(1);
dt = open("$SAMPLE_DATA\Consumer Prices.jmp"); dt << Process Screening( Y( :Price ), Grouping( :Series ), Control Chart Type( "Indiv and MR" ), Time( :Date ), Subgroup Sample Size( 1 )// this can't happen );
You should get a warning in log saying
Minimum subgroup size is 2.
If you do this via the GUI then it should actually give you a popup.
If you take your process screening and save to script window I'm guessing it overwrote your Subgroup Sample Size( 1 ) with a 2.
Even if you give it a subgroup column, it should do this.
Vince Faller - Predictum
vince_faller
tova
Community Trekker
Thank you!!
