Process Capability
Trying to add a list of the variables (“Process Variables”) in Process Capability plot.
It works for single item from the list, but it does not work for whole list.
lTest = Data Table("dtGoal") << get column names( numeric);
Data Table("dtGoal") << Process Capability(
       Process Variables( eval(lTest[i]) ), // it works for any i
//  Process Variables( eval(lTest) ),  // does not work
_ _ _ _ _
Thanks
Re: Process Capability
Here is a working version of the script.  It bypasses the requirement to add the spec limits to the platform code by moving the limits into column properties for the columns in the data table.
dt = Open( "$sample_data/big class.jmp" );
dtSpecLimits = New Table( "MySpecLimits",
       Add Rows( 3 ),
       New Column( "Parameter", Character, Nominal, Set Values( {"height", "weight", "age"} ) ),
       New Column( "LSL", Continuous, Set Values( [0, 0, 0] ) ),
       New Column( "Target", Continuous, Set Values( [50, 100, 50] ) ),
       New Column( "USL", Continuous, Set Values( [99, 200, 100] ) )
//dtSpecLimits << Save( "C:\Users\user\Documents\MySpecLimits.jmp" );
ltest = dt << getcolumnnames( numeric );
Substitute Into( ltest, Expr( List() ), Expr( Process Variables ) );
// Process the Spec Limits and add them as column properties to the data table
For( i = 1, i <= N Rows( dtSpecLimits ), i++,
       Eval(
              Substitute(
                           Expr(
                      __var__ << set property(
                                         "Spec Limits",
                                         {LSL( __LSL__ ), Target( __Target__ ), USL( __USL__ ), show limits( 1 )}
                     Expr( __var__ ), Parse( "dt:" || dtSpecLimits:Parameter ),
                     Expr( __LSL__ ), dtSpecLimits:LSL,
                     Expr( __Target__ ), dtSpecLimits:Target,
                     Expr( __USL__ ), dtSpecLimits:USL,
Eval(
       Substitute(
                     Expr(
                 dt << Process Capability( FIXME(), Goal Plot( 1 ), Capability Index Plot( 1 ) )
              Expr( FIXME() ),
                     Name Expr( ltest ) // ...with ltest
Craige_Hales
I hope someone chimes in with a better way.  This should work... "FIXME()" is an arbitrary placeholder that the substitute() function can find and replace with the proper expression.
show(nameexpr(ltest)); // Process Variables(age, height, weight);
e = Substitute(
  Expr(
  Process Capability(
  FIXME(), // replace this...
  Spec Limits(
  height( LSL( 0 ), Target( 50 ), USL( 99 ) ),
  weight( LSL( 0 ), Target( 100 ), USL( 200 ) ),
  age( LSL( 0 ), Target( 50 ), USL( 100 ) )
  Goal Plot( 1 ),
  Expr( FIXME() ), Name Expr( ltest ) // ...with ltest
show(nameexpr(e)); // Process Capability(Process Variables(age, height, weight), ...
eval(e); // open the platform
Craige
Thanks. It works, but I cannot import spec limits from the saved Spec Limits Table.
Add Rows( 3 ),
New Column( "Parameter", Character, Nominal, Set Values( {"height", "weight", "age"} )),
New Column( "LSL", Continuous, Set Values  ( [0, 0, 0] ) ),
New Column( "USL", Continuous, Set Values  ( [99, 200, 100] ) )
dtSpecLimits << Save("C:\Users\user\Documents\MySpecLimits.jmp");
e = Substitute(
Expr(
Process Capability(
Spec Limits( Import Spec Limits("C:\Users\user\Documents\MySpecLimits.jm")),
Spec Limits Dialog( "No (skip columns with no spec limits)" ),
1,
Show Within Sigma Points( 1 ),
Show Overall Sigma Points( 0 ),
Shade Levels( 1 )
       Add Rows( 3 ),
       Eval(
              Substitute(
                           Expr(
                                         "Spec Limits",
Eval(
       Substitute(
                     Expr(
              Expr( FIXME() ),
Thanks everybody for the help.
