aatw
Problem when running jmp script from python
I am trying to link Python and JMP for the first time. I would like to run a jsl script directly from python. I am following this example:
Using JSL Commands in the Python Script Editor
However, I get the error:
ModuleNotFoundError: No module named 'jmp'
Where to get jmp library for python? Should I include some specific location to PATH?
Thanks!
Re: Problem when running jmp script from python
You have to run the Python from within JMP, The Python Script Editor
aatw
Thanks, that makes sense.
