BookmarkSubscribeRSS Feed
Problem facing while reading document from C# Visual studio
ORANALYST17
Community Member
Jul 12, 2017
class Program
static void Main(string[] args)
JMP.Application myjmp;
myjmp = new JMP.Application();
JMP.Document doc;
doc = myjmp.OpenDocument("data.xlsx");
JMP.Distribution dist;
dist = doc.CreateDistribution();
I am getting doc as null. even I have tried to read .jmp data file but still i am getting null. I am new in JMP. Please help me out.
1 REPLY
briancorcoran
Jun 23, 2011
Have you tried fully qualifying the path to the file, like
doc = myjmp.OpenDocument("c:\\program files\\sas\jmp\\13samples\\data\\data.xlsx");
Please notice that for C# you need \\ for slashes in the path.
There is a C# example that ships with JMP.  For JMP 13, you would find this in C:\Program Files\SAS\JMP\13\Samples\Automation\Visual C# Sample\JMPStarter .
Looking at the sample should give you a good idea how to do most automation operations with C# and JMP.
Brian Corcoran
JMP Development
