BookmarkSubscribe
M22
M22
Community Member
Problem Opening up Saved JMP Journal
For homework, I was doing a project using JMP where I would create graphs using a data set and then describe the significance of the results. I saved my work in a JMP Journal along with my notes. When I try to open up the Journal now, there is an error message that pops up saying: Parsing problem after key[Richmond city]. Expected ")", but found "rowStates". Once this message pops up, JMP stops working and I have to shut it down. I need the work that I did in the Journal to submit to my professor to receive a grade. Is there any way for me to get into the file?
