chalpern
Problem Note 41989: Using JSL might generate an incorrect design in JMP
Problem Note 41989 was created in 2010 and modified in 2011. It states that
"There are designs with various options that are not available using the interface with the JMP® DOE platform, such as adding random blocks to a split plot design, adding center points to random block design. You can use JSL to generate these designs with these options; however, the resulting design is not correct.
There is not a circumvention to this problem.
Question: Has this problem been resolved in JMP 15 Pro?
