LeeP
Prevent Objects From Displaying When Running Scripts
I'm trying to automate my JMP chart creation. I'm creating an application.As the script runs it displays the output of the query and the report. It then saves the report as an HTML document. The full script has 4 different queries and reports. Is there a way to run the script where it doesn't display anything? I plan on having the application show a pop-up saying the report is running, but don't want the actual artifacts displaying. Attached is a sample script.
planetQ = New SQL Query(
	Connection(
		"CONNECTION INFO HERE"
	QueryName( "ON_TIME_SPC_PLANET" ),
	Select(
		Column( "ReleaseMonth", "t1", Numeric Format( "m/d/y", "-1", "NO", "" ) ),
		Column( "PLANET", "t1" ),
		Column(
			"On-Time",
			"t1",
			Alias( "Sum-On-Time" ),
			SavedJMPName( "On-Time" ),
			Aggregation( "Sum" ),
			JMP Name( "Sum-On-Time", 0 )
		Column(
			"Total",
			"t1",
			Alias( "Sum-Total" ),
			SavedJMPName( "Total" ),
			JMP Name( "Sum-Total", 0 )
		Column( "Phase", "t1", Analysis Type( "Nominal" ) )
	From( Table( "ON_TIME_SPC", Schema( "dbo" ), Alias( "t1" ) ) ),
	Group By(
		Column( "Phase", "t1" )
	Order By(
		Column(
			"ReleaseMonth",
			"t1",
			Numeric Format( "m/d/y", "-1", "NO", "" ),
			Order( "Ascending" )
) << Run Foreground();
planetQ << New Column( "OnTimePct",
	Formula( :Name( "Sum-On-Time" ) / :Name( "Sum-Total" ))
wait(1.0);
current data table(planetQ);
planetP = Control Chart(
	Sample Label( :ReleaseMonth ),
	Phase( :Phase ),
	Sample Size( :Name( "Sum-Total" ) ),
	KSigma( 3 ),
	Chart Col( :OnTimePct, P( Phase Level( "1" ), Phase Level( "2" ) ) ),
	By( :PLANET )
3 ACCEPTED SOLUTIONS
Re: Prevent Objects From Displaying When Running Scripts
You should be able to specify to run your query in "Background".  Look in the Scripting Index under SQL Query for "Run Background".  And as for the Control Chart, you can always specify the "Invisible" option.
ppnP = Control Chart(invisible,
Sample Label
( :ReleaseMonth ),
Phase
( :Phase ),
Sample Size
KSigma
( 3 ),
Chart Col
By
( :name )
Jeff_Perkinson
LeeP
Thanks for the response. I was able to hide the tables by using the "private" option (since I didn't want to have to close them when done) I am not seeing where I would use the invisible option when generating the chart:
	Phase( :Phase ),
	KSigma( 3 ),
	By( :name )
Sample Label
( :ReleaseMonth ),
Phase
( :Phase ),
Sample Size
KSigma
( 3 ),
Chart Col
By
( :name )
Jeff_Perkinson
LeeP
Thanks for the quick response. Works perfectly.
