JohannesENS
Prediction Profiler without DoE
Hello everybody,
I have a dataset with factors and responses. The experiments were already conducted.
Can I analyze the data by prediction profiler although I have not generated a DoE-Experiment before conducting the experiments? See a screenshot attached.
Thank you.
Re: Prediction Profiler without DoE
The Prediction Profiler is available for any model. Most of the model fitting platforms, for example, Fit Least Squares, provide a profiler for the current model. Furthermore, you can save the current model as a column formula and then use the separate Graph > Profiler platform without having to go through the fitting process again.
So fit your model to the available data and you should be able to profile the model!
JohannesENS
Thank you. I got it
