tam3
Precision column format does not "Keep all whole digits" after re-opening data table
Using JMP 15.0.0, I use a script to set specific column formats and use the Precision format with the option for "Keep all whole digits" checked:
column(1) << Format("Precision", Use thousands separator(1), Keep trailing zeroes(0), Keep all whole digits(1), 41, 5);
After applying my script, the column properties for the Precision columns are correct and the data table script shows the formatted columns correctly:
Format(
			"Precision",
			Use thousands separator( 1 ),
			Keep trailing zeroes( 0 ),
			Keep all whole digits( 1 ),
			41,
			5
However, when I save and reopen the same data table file, the "Keep all whole digits" option is no longer checked and the data table script no longer contains that particular entry at all:
Format(
			"Precision",
			41,
			5
No additional scripts are run upon opening the file. The same issue happens when the "Keep all whole digits" is checked, the file is saved, and re-opened. I did not find any options to prevent this within JMP preferences.
How do I prevent this from happening?
Re: Precision column format does not "Keep all whole digits" after re-opening data table
Sounds like a bug.....I would contact JMP Support @
     support@jmp.com
