viskovicz00012
Ppt Help
Im kinda lost with having to append the output of this into ppt slides -- my aim is each slide has 4 columns and two rows.
Here's what I've done so far
params = New Window( "Parameters vs WEW (Design)",
                                V List Box(
                                        Lineup Box( N Col( NST ),
                                                For( i = 1, i <= N Items( colnamey ), i++,
                                                        biv = Bivariate(
        Y( Column( dt, colnamey[i] ) ),
        X( Column( dt, colnamex[i] ) ),
        By( :STO ),
        Group By( Column( dt, groupname ) ),
        Fit Spline( 1000 )
                                                        rbiv = biv << report;
                                                        For( k = 1, k <= NST, k++,
        rbiv[k][FrameBox( 1 )] << {Frame Size( 250, 200 ),
        Marker Size( 0 ), Line Width Scale( 2 )};
        rbiv[k][axis box( 2 )] <<
        Tick Font( style( 1 ), size( 9 ) ) <<
        Format( Best, 5 ) << Show Major Grid( 1 ) <<
        Show Minor Grid( 1 ) << Show Minor Ticks( 1 );
        rbiv[k][axis box( 1 )] <<
        rbiv[k][Text Edit Box( 2 )] << Set Font Size( 10 )
        << Set Font Style( "Bold" );
        rbiv[k][Text Edit Box( 1 )] << Set Font Size( 10 )
                                                        For( b = 1, b <= N Items( GroupList ), b++,
        fitcrve = "biv << (curve[" || Char( b ) ||
        "]<<report(0))
        fitcrve = Eval( Parse( fitcrve ) );
pmroz
Re: Ppt Help
Try params << save presentation().  Here's an example:
Open( "$SAMPLE_DATA/Big Class.jmp" );
nw = new window("Example",
	vlb = vlistbox(
		table box(
			string col box("Hello", {"ABC", "DEF", "GHI"}),
			number col box("World", {100, 200, 300}),
		biv = bivariate( y( :weight ), x( :height ) ),
nw << Save Presentation( "$TEMP/jmp_example.pptx" );
Open( "$TEMP/jmp_example.pptx" );
This puts the tablebox and bivariate analysis on separate pages.  Not sure how to put it all on one page.
Re: Ppt Help
This topic has been answered before.   Here is the link to it.
