Jeremy122
Possible to create x number of lists, where x is the number of loops in For statement?
Is there anyway to script in creating a variable number of lists depending on the number of loops in a for statement? I was thinking something like below would work, but no luck.
xyz = N Items( List1 );
NumOfSets = Divide To( xyz, 4 );
For( i = 1, i <= NumOfSets, i++,
	List( Concat( Set, Char( [i] ) ) )
pmroz
Re: Possible to create x number of lists, where x is the number of loops in For statement?
Something like this?  I'm creating a list of lists.
list1 = {"aaa", "bbb", "ccc", "ddd", "eee", "fff", "ggg", "hhh"};
list_array = {};
set = "xyz";
	list_array[i] = eval list(list( Concat( Set, Char(i) )));
list_array;
pmroz
list_array = {};
set = "xyz";
list_array;
Jeremy122
Yes, it looks like that will do the trick. Thank you
