BookmarkSubscribeRSS Feed
Possible code bug with limit extraction
Hi Guys,
I am using the following JMP snippet as a part of a larger program. Problem is I get a invalid row number -1 error. When I step through the code with the debugger once and then run the code, I do not get this error and everything runs fine. What may be wrong with this code?
7 REPLIES 7
pmroz
Re: Possible code bug with limit extraction
Try using different variable names for lsl and usl. If they are column names JMP gets very confused.
my_lsl = mysl["LSL"];
my_usl = mysl["USL"];
Regards,
Peter
mpb
Super User mpb
What do you get when you insert show(col1, mysl) after the mysl = line? You should get something like this in the log:
col1:Column("Weight")
mysl:{LSL(65), USL(80)}
@Peter:
That worked. It's weird that JMP does not differentiate between upper case and lower case variables.
@mpb:
I was getting exactly what you showed in the log window which is why I was puzzled how the next limit extraction statement would not work.
Ok on the same lines, I get another error when the lsl or the usl is missing from the column. How can I handle this? I am ignoring the columns with missing lsl or usl with the Is missing statement:
ms
Super User ms
You must insert the conditional tests before the assignments to avoid addressing a non-existent name. Try something like this...
I tried that and I am getting an error N Items() argument must be a list. Is the col1 variable a list only when there is a valid limit maybe?
mpb
Super User mpb
Yes. Use the function is list() to check if you have any limits associated with the column being processed.
