BookmarkSubscribeRSS Feed
robot
Feb 27, 2012
Polynomial Fit Parameter Term Name Changes: Bug?
I am writing a script that generates a second degree polynomial fit and then uses the parameter estimates in further calculations.  My problem is the second order parameter estimate term name changes as a function of the input values, when it seems to me it should not.  This term name change causes subsequent calculations to fail.
For example, the script below will generate a second degree polynomial fit with the following terms:
Intercept
height
(height-62.55)^2
My question is, why is the second order term name "(height-62.55)^2"?  Shouldn't the term name be "height^2"?  This name will change as a function of the input values.  Is this a bug?
Any insights or workarounds are appreciated.
Thanks!
bigClass=open("$SAMPLE_DATA/Big Class.JMP");
bigClass << Bivariate(
  Y( :weight ),
  X( :height ),
  Fit Polynomial( 2, {Line Color( {213, 72, 87} )} )
mpb
Jun 23, 2011
Solution
Re: Polynomial Fit Parameter Term Name Changes: Bug?
By default JMP Bivariate Fit Polynomial generates a model with the terms of order 2 and greater centered around the mean of the X variable. It names the coefficients of those terms in a way that communicates what it did.
Instead use Fit Special, make sure neither X nor Y is transformed, change the degree to "2 quadratic" and uncheck "Centered Polynomial".
robot
Feb 27, 2012
Note: I am using JMP10.
mpb
Jun 23, 2011
Solution
robot
Feb 27, 2012
Works great.  Thanks!
