qt
qt
Plotting, using script vs. interactively.
Hi, JMP experts,
I have a general question on using JMP to plot.
The interactive plotting is very intuitive, we selected columns (Y1, Y2, Y3, vs X), then plot (Y-X scatter), for example, then we have multiple plots in one frame. When we push down 'Control' button, we can adjust the axis, mark size, line thickness, etc, altogether.
Since I need to make some plots many times, so I saved the scripts. The things is with script, each plot is in one frame, so I have to click on each plot to change the axis setting, etc.
Bivariate(
    Y( :Y1 ),
    X( : X )
Bivariate(
    Y( :Y2 ),
    X( : X )
Can I plot them in one frame, so 'Control' button will work again?
Thanks,
Qian
Article Labels
