Juber
Plot Y axis with different names as the function gets called
I'm trying to create a generic graph function for various data tables. So the Y axis column's names also vary and I couldn't find a way to plot it based on the title  pass it.
title = "no. of people";
gb = graph_func(stackdt,title);
graph_func = function({stackdt,title},{Default Local},
				gb = Graph Builder(
					Size( 1342, 905 ),
					Variables(
						Y( :title),
						Group X( :Type ),
						Group X( :Stat ),
						Overlay( :MATRIX_GROUP )
					Elements( Box Plot( Y, Legend( 25 ) ), Caption Box( Y, Legend( 26 ) ) ),
				return(gb);
Stackdt has a column that's named as no. of people and this name will vary if i call a function for a different data table. I know title is not a column, so it doesn't recognize it but how can i plot this. I've also tried passing in the column but I couldn't get it to work either probably because it didn't get copied.
Re: Plot Y axis with different names as the function gets called
If I am understanding what the issue is, I believe all you need to do is to use the As Column() function to clarify to JMP to use the memory variable "title" as a column.  See my example below:
names default to here(1);
stackdt=open("$SAMPLE_DATA/big class.jmp");
Graph Builder(
	Size( 525, 490 ),
	Show Control Panel( 0 ),
	Variables( X( :age ), Y( as column( title ) ), Group X( :sex ) ),
	Elements( Points( X, Y, Legend( 4 ) ) )
title = "height";
Graph Builder(
	Size( 525, 490 ),
title = "height";
Juber
Thanks, that did the job :).
