BookmarkSubscribeRSS Feed
novicescriptor
Community Trekker
Oct 1, 2012
Please recommend best tool for correlating large number of input parameters to categorical outcome
My question is best described using a sample table below:
Calibration ParametersPerformance Result
SNPAR1PAR2PAR3PAR4PAR5P/F
10353.4144.224.431158120.8P
11683.7546.694.601149121.6P
18343.9442.214.481144121.2P
20623.6344.764.441155121.2P
21923.6046.095.161150121.5F
26703.2446.783.891141121.3P
27123.7046.625.851143121.2F
32473.4748.265.571168121.0F
46793.6646.735.001142120.6F
47033.5546.074.601146120.8P
48953.4047.694.921149120.4P
50073.8246.684.621140121.3P
57873.3744.375.621150120.9F
59013.3644.614.241142120.8P
70903.7247.115.601161121.3F
80883.3048.256.991146120.3F
82593.3946.785.671156121.0F
83293.6145.234.951151121.6F
86743.3546.024.821144122.1F
90173.6448.245.671154121.3F
In the real case there are thousands of input adjustments or calibration data. The output is actually categorized into sections also, but if the high level  objective here is to take a black box approach to narrow down the field, so a more detailed analysis can be done. i.e, we want to know which parameters(s) rank high in affecting the outcome with high degree of correlation?  (pass if above/below a certain threshold, with increasing confidence as you move away from  the threshold).
I have successfully used the Partition tool to arrive at the answer using the data above - the answer is Parameter 3 at 4.95.
My quandry is the large number of parameters in the thousands and ideally the tool can be scripted to 'float up' the key parameters only, with no interactive input from user.
I hope I have described the question adequately - feel free to ask if I have left out anything.
Thanks,
Barry
