Permutations Function
I've been looking through the JMP 8 manual for a function that returns every possible permutation of all the integers from 1 to N, but haven't been able to find one. I can write one easily enough, but I don't want to bother if there's one already available that I've overlooked. Is there one?
7 REPLIES 7
mpb
Super User mpb
Re: Permutations Function
Can the "col shuffle" function do what you need?
Unfortunately no: I need to look at every permutation systematically. As I said, I can write a function that will do it easily enough; I'm just a little surprised that there doesn't already appear to be one. I'd have thought that it would be a useful addition to the armoury.
Many thanks
ms
Super User ms
You can achieve that with the "Cartesian Join" option in the Join platform. Create two tables with one column each and n rows. Join the second with the first table, and then rejoin the output with first n-1 times. I tried with n=3 and got a table with 27 rows containing every permutation (distributed over 3 columns).
Would be easy to script in a for loop (use invisible option for large n!), but that was maybe what you already had in mind.
Ingenious! But that's going to generate 27 (3x3x3) lists, i.e. {1, 1, 1}, {1, 1, 2}, {1, 1, 3}, {1, 2, 1}, ... , {3, 3, 3}, isn't it, whereas what I'd actually be after in such a situation would be just the following 6 (3x2x1) lists:
{1, 2, 3}, {1, 3, 2}, {2, 1, 3}, {2, 3, 1}, {3, 1, 2} and {3, 2, 1}
I could eliminate any of the lists generated from the cartesian join with duplicate integers easily enough, but there ought to be a more efficient way than that - maybe using a recursive function. If I think one up I'll post it unless anyone beats me to it.
Many thanks!
I've found one that was originally written in C++ and just translated it into JSL as shown below. The original can be found, with some others, at www.bearcave.com/random_hacks/permute.html
style="font-size: 9pt; font-family: "Courier New"; color: black;">
style="font-size: 9pt; font-family: "Courier New"; color: green;">/*
Translated from the University
of Exeter algorithm */
style="font-size: 9pt; font-family: "Courier New"; color: black;">permute
style="font-size: 9pt; font-family: "Courier New"; color: navy;">=
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">function
style="font-size: 9pt; font-family: "Courier New"; color: black;">({
style="font-size: 9pt; font-family: "Courier New"; color: black;">v
style="font-size: 9pt; font-family: "Courier New"; color: navy;">,
start}
{default
local}
style="">
n
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">nitems
style="font-size: 9pt; font-family: "Courier New"; color: black;">v)
style="font-size: 9pt; font-family: "Courier New"; color: navy;">;
style="">
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">if
style="font-size: 9pt; font-family: "Courier New"; color: black;">start
style="font-size: 9pt; font-family: "Courier New"; color: navy;">==
style="font-size: 9pt; font-family: "Courier New"; color: black;">n
style="font-size: 9pt; font-family: "Courier New"; color: navy;">-
style="font-size: 9pt; font-family: "Courier New"; color: teal;">1
style="">
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">print
style="">
style="">
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">for
style="font-size: 9pt; font-family: "Courier New"; color: black;">i
i
style="font-size: 9pt; font-family: "Courier New"; color: navy;"><
i
style="font-size: 9pt; font-family: "Courier New"; color: navy;">++,
style="">
tmp
v[i
style="font-size: 9pt; font-family: "Courier New"; color: black;">]
v[i
v[start
v[start
tmp
style="">
permute(v
start
style="font-size: 9pt; font-family: "Courier New"; color: black;">)
style="">
v[start
v[i
v[i
tmp
style="">
style="">
style="">
Try it out on some lists */
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">clear
log
style="font-size: 9pt; font-family: "Courier New"; color: black;">()
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"Example
1
(there should be 4! = 24 perms)"
style="font-size: 9pt; font-family: "Courier New"; color: teal;">2
style="font-size: 9pt; font-family: "Courier New"; color: teal;">3
style="font-size: 9pt; font-family: "Courier New"; color: teal;">4
style="font-size: 9pt; font-family: "Courier New"; color: black;">}
style="font-size: 9pt; font-family: "Courier New"; color: black;">permute(v
style="font-size: 9pt; font-family: "Courier New"; color: teal;">0
2
(there should be 6! = 720 perms"
style="font-size: 9pt; font-family: "Courier New"; color: teal;">6
style="font-size: 9pt; font-family: "Courier New"; color: teal;">5
3
(there should be 5! = 120 perms"
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"Albert"
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"Bessie"
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"Carrie"
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"David"
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"Edgar"
As a postscript, after finding the above I started looking on the internet for a similar recursive function to evaluate all the combinations of k items from N, but realised that it's a lot easier if you just create a multiple loop of the necessary depth in text and then parse it. The following function does that: to see the text that's being parsed, just uncomment the last line but two:
style="font-size: 9pt; font-family: "Courier New"; color: black;">All_N_Choose_k
style="font-size: 9pt; font-family: "Courier New"; color: black;">N
k}
{default
local}
style="">
c
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">repeat
k)
icount
style="">
answer
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">matrix
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">N
Choose k
k)
k)
style="">
i
style="font-size: 9pt; font-family: "Courier New"; color: navy;"><=
style="font-size: 9pt; font-family: "Courier New"; color: black;">k
i
style="">
style="">
TextToParse
style="">
for(c[1]=1,
c[1]<=N-"
style="font-size: 9pt; font-family: "Courier New"; color: navy;">||
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">char
style="font-size: 9pt; font-family: "Courier New"; color: black;">i)
style="font-size: 9pt; font-family: "Courier New"; color: purple;">",
c[1]++,"
style="">
style="">
TextToParse
TextToParse
style="">
for(c["
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"]=c["
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"]+1,
c["
style="">
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"]<=N-"
c["
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"]++,"
style="">
style="">
style="">
TextToParse
TextToParse
style="">
icount++;
for(i=1, i<=k, i++, answer[icount, i] = c[ i ])"
style="">
i
i
TextToParse
TextToParse
style="font-size: 9pt; font-family: "Courier New"; color: purple;">")"
style="font-size: 9pt; font-family: "Courier New"; color: green;">//
style="">
show(TextToParse);
style="">
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">eval
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">parse
style="font-size: 9pt; font-family: "Courier New"; color: black;">TextToParse))
style="">
answer
style="">
style="font-size: 9pt; font-family: "Courier New"; color: black;">W
All_N_Choose_k(
style="font-size: 9pt; font-family: "Courier New"; color: teal;">10
dtw
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">as
table
style="font-size: 9pt; font-family: "Courier New"; color: black;">W)
style="font-size: 9pt; font-family: "Courier New"; color: black;">X
All_N_Choose_k(
style="font-size: 9pt; font-family: "Courier New"; color: teal;">15
dtx
table
style="font-size: 9pt; font-family: "Courier New"; color: black;">X)
style="font-size: 9pt; font-family: "Courier New"; color: black;">Y
All_N_Choose_k(
style="font-size: 9pt; font-family: "Courier New"; color: teal;">20
dty
table
style="font-size: 9pt; font-family: "Courier New"; color: black;">Y)
style="font-size: 9pt; font-family: "Courier New"; color: black;">Z
All_N_Choose_k(
dtz
table
style="font-size: 9pt; font-family: "Courier New"; color: black;">Z)
style="font-size: 9pt; line-height: 115%; font-family: "Courier New"; color: navy;">
The above also illustrates just how fast the calculations are being done (on my machine it's less than one second), bearing in mind that the last of the four tables created by the examples at the bottom contains 20! / ((6!) x (14!)) = 38,760 rows.
ms
Super User ms
Thanks for sharing these functions.
You're right about that mine suggestion was giving the wrong result. The Cartesian Join does not yield permutations. It's more like all the possible outcomes in an old urn problem: draw n balls with replacement after each draw (I come think of the multinomial distribution beeing related to this..)
