Bandfield
Passing user specified value to Open Database() SQL block
Good day,
  I currently have a block of SQL code being executed through an Open Database() command. This SQL block was generated by another person and I am trying to streamline the user interface. Currently an order number is manually entered in the SQL block and must be overwritten everytime a new order number is desired. I have built a JMP GUI that pulls a user specified order number.
 I would like to pass this user specified order number into the SQL code.
SQL segment where the current order number is manually entered (25891769)
where
	ShopFloorControl.ManufacturingOrder.OrderNumber in (25891769)
	and ShopFloorControl.ManufacturingOrder.LineNumber = 0
Any assistance would be greatly appreciated.
Thank you
pmroz
Re: Passing user specified value to Open Database() SQL block
You can use string concatenation to replace a variable in the SQL statement.  Here's one way to do it:
order_no = "25891769";
sql_statement = evalinsert(
"SELECT ...
   FROM ...
  WHERE
	ShopFloorControl.ManufacturingOrder.OrderNumber in ('^order_no^')
	and ShopFloorControl.ManufacturingOrder.LineNumber = 0");
print(sql_statement);
Results in:
"SELECT ...
   FROM ...
  WHERE
	ShopFloorControl.ManufacturingOrder.OrderNumber in ('25891769')
If you have more than one order number you can use CONCAT ITEMS to create an IN list:
order_list    = {"25891769", "25891770", "25891771"};
order_inlist  = "('" || Concat Items(order_list, "', '") || "')";
"SELECT ...
   FROM ...
  WHERE
	ShopFloorControl.ManufacturingOrder.OrderNumber in ^order_inlist^
Results in:
"SELECT ...
   FROM ...
  WHERE
	ShopFloorControl.ManufacturingOrder.OrderNumber in ('25891769', '25891770', '25891771')
pmroz
"SELECT ...
   FROM ...
  WHERE
Results in:
"SELECT ...
   FROM ...
  WHERE
"SELECT ...
   FROM ...
  WHERE
Results in:
"SELECT ...
   FROM ...
  WHERE
Bandfield
Thank you for the assistance. This worked just as I needed.
