BookmarkSubscribeRSS Feed
lenny
Community Trekker
Passing Marker states to a journal
This may seem like a rather silly question but I am having trouble with a Bivariate Graph being sent to a journal. I define the marker type as alphanumeric one of the columns but it seems that if there are more than 4 variables it wont display them on the graph they default back to points even though the legend shows them as alphanumeric. Is there something a miss or am I doing something wrong? Or is there a better way to achieve my result?
Thank you in Advance.
Lenny
graph = H List Box(temp5 << Bivariate(
Y( :columnA),
X( :columnB),
  Dispatch(
   "1",
   ScaleBox,
   {Add Ref Line( 6, Solid, {255, 0, 0}, "UCL" ), Rotated Labels( 1 )}
  Dispatch(
   "2",
   ScaleBox,
  Dispatch(
   "Bivar Plot",
   FrameBox,
   {Frame Size( 522, 251 ), Row Legend(
    columnA,
    Color( 0 ),
    Color Theme( "" ),
    Marker( 1 ),
    Marker Theme( "Alphanumeric" ),
    Continuous Scale( 0 ),
    Reverse Scale( 0 ),
    Excluded Rows( 0 )
   ), Row Legend(
    columnB,
    Color( 1 ),
    Color Theme( "JMP Default" ),
    Marker( 0 ),
    Marker Theme( "" ),
    Reverse Scale( 0 ),
    Excluded Rows( 0 )
)<<journal;
lenny
Community Trekker
Re: Passing Marker states to a journal
Ah I knew this something easy, I needed to set the marker drawing mode to Normal.
Marker Drawing Mode( "Normal" )
lenny
Community Trekker
