This may seem like a rather silly question but I am having trouble with a Bivariate Graph being sent to a journal. I define the marker type as alphanumeric one of the columns but it seems that if there are more than 4 variables it wont display them on the graph they default back to points even though the legend shows them as alphanumeric. Is there something a miss or am I doing something wrong? Or is there a better way to achieve my result?
Thank you in Advance.
Lenny
graph = H List Box(temp5 << Bivariate(
Y( :columnA),
X( :columnB),
Dispatch(
"1",
ScaleBox,
{Add Ref Line( 6, Solid, {255, 0, 0}, "UCL" ), Rotated Labels( 1 )}
Dispatch(
"2",
ScaleBox,
Dispatch(
"Bivar Plot",
FrameBox,
{Frame Size( 522, 251 ), Row Legend(
columnA,
Color( 0 ),
Color Theme( "" ),
Marker( 1 ),
Marker Theme( "Alphanumeric" ),
Continuous Scale( 0 ),
Reverse Scale( 0 ),
Excluded Rows( 0 )
), Row Legend(
columnB,
Color( 1 ),
Color Theme( "JMP Default" ),
Marker( 0 ),
Marker Theme( "" ),
Reverse Scale( 0 ),
Excluded Rows( 0 )
)<<journal;
Ah I knew this something easy, I needed to set the marker drawing mode to Normal.
Marker Drawing Mode( "Normal" )
