bipppp
Parsing a Named List from Degradation Platform
I am using the Analysis>Reliability and Survival>Degradation platform to do some analysis. In my script, I am saving the results, which is output as a Named List by JMP.
Results = obj << Get Results;
Show(Results);
The resultant named list is as follows:
Results = {Model 1 Simple Linear Path(
	{N Param( 5 ), DF( 67 ), SSE( 0.372577539987142 ), AICc( -163.770048207164 ),
	BIC( -153.295808521175 ), RSquare( 0.999768602768815 ),
	Estimates(
		{Beta(
			[0.389607728081622, -1.23431047684725, -0.792888109911265, -0.136038220958541,
			-0.223824276464951]
		), Std Dev(
			[0.00706176641928502, 0.0223919804438757, 0.0223919804438757, 0.0223919804438757,
			0.0223919804438757]
From this named list, I would like to extract only the Beta matrix from Estimates. I am not able to use list subscripts for doing this.
Please help!
Thanks
Re: Parsing a Named List from Degradation Platform
You were on the right tract. The key is to subscript the list, but they are nested. Use this example of the correct syntax:
beta = Results["Model 1 Simple Linear Path"]["Estimates"]["Beta"];
bipppp
Worked wonderfully! Thank you very much @markbailey
