fr2007
Pareto Graph-"Others" column at the end-please help
Iam trying to draw a Pareto graph with the below data
   Cause Category                                             Cost                                        Cumulative %
Assy: Operator Error                                      $25040.00                                65.8%
Machine Shop Personnel                                  $3013.00                                74.8%
Weld Shop Personnel                                   $1087.00                                   78.2%
Assy: Damaged during assembly                  $1192.00                                    81.2%
Vendor related                                             $1659.00                                         84.0%
Vendor related: Assembly error                     $1398.00                                       86.7%
Other causes/damage: Cause not found       $7396.00                                       88.6%
Others                                                          $6299.00                                  100.0%
How do I draw a pareto such that the "Others" cause category is at the end ?
Thanks,
Jeff_Perkinson
Re: Pareto Graph-"Others" column at the end-please help
In the Pareto Plot, click on the Others bar to select it, and then choose "Causes->Move to Last" from the red triangle menu.
-Jeff
-Jeff
