Fabrizio_Ruo
Overwrite Excel Sheet
I can create new sheets in a Excel file using "Create Excel Workbook" without any issue only if the sheets do not exist in the excel file.
The problem come when the sheets already exist in the excel file and I try to overwrite them.
There are some cells that remains with the old data, and I do not want them!
Is there a way to have a full overwite of the sheets usign "Create Excel Workbook" ?
Is there a way to delete a single sheet in an Excel file?
Thanks,
Fabrizio
Re: Overwrite Excel Sheet
Hi Fabrizio,
Create Excel Workbook tries to do a replacement if the file already exists and the worksheet names match existing worksheet names.  If that is not the case, it creates new sheets.  Unfortunately, there is no way to override the behavior other than to provide different sheet names or a different file name prior to the save.
Brian Corcoran
JMP Development
Fabrizio_Ruo
Hi Brian,
is there a way to delete a single sheet from an Excel file?
Thanks,
Fabrizio
Hi Fabrizio,
Sorry, no, there are no circumstances where we delete sheets from an existing workbook.
Brian
jimmsky
//I hope this will help you, this will delete your workbook
excel_path = "$Desktop\test.xlsx"
save text file(delSheetpath = "$Desktop\deleteExcelSheet.vbs",
Set objFSO = CreateObject("Scripting.FileSystemObject")
Dim oExcel
Set oExcel = CreateObject("Excel.Application")
Dim oBook
Set oBook = oExcel.Workbooks.Open("]\"||excel_path||"\[")
oExcel.DisplayAlerts = False
oExcel.ScreenUpdating = False
oBook.sheets("]\"||sheet_name||"\[").Delete
oBook.save
oBook.close
oExcel.DisplayAlerts = True
oExcel.ScreenUpdating = True
oExcel.Quit
open(delSheetpath);
