BookmarkSubscribeRSS Feed
maarten
Jun 18, 2013
Overlay plot for timeseries from 2 tables
I am doing experiments where I create timeseries for each run, i.e. I have a laser measuring distance and each run is executed under different circumstances.
I would like to check whether there are some patterns and hence would like to use overlay plots.
The challenge for which I am seeking help is that the time axis (X) - for each run is different. Because of this, I did not manage to join the 2 tables.
I am attending a couple of datatables, each for 1 run.
  • The column to match is time: range from 0 to about 1500 [ms] - intervals are multiples of 0.125 [ms]
  • Number of datapoints per run is about 60 to 130
  • I would like to plot height or C-2-C (time distance to previous point) and have this as an overlay plot for the different runs
  • Because the starting point is not controlled, measurements may start at different timings - it would be ok to rescale to have the first measurement at time = 0.000 [ms]
How could I do this using JMP?
Maarten
pmroz
Jun 23, 2011
Re: Overlay plot for timeseries from 2 tables
Here's an approach that's hard-coded to the 4 tables listed above.  Zeroes out each time column using the first time.
tbl_list = {"2013-05-02_18-34-27_peaks", "2013-05-02_18-35-09_peaks", "2013-05-02_18-35-26_peaks",
            "2013-05-02_18-35-45_peaks"};
for (i = 1, i <= nitems(tbl_list), i++,
    dt = data table(tbl_list[i]);
    dt << new column("Dataset", Character, nominal, << set each value (tbl_list[i]));
    dt << new column("Adj Time", numeric, continuous);
    zero_time = dt:Time[1];
    for (k = 1, k <= nrows(dt), k++,
        dt:Adj Time[k] = dt:Time[k] - zero_time;
Data Table( "2013-05-02_18-34-27_peaks" ) <<
Concatenate(
    Data Table( "2013-05-02_18-35-45_peaks" ),
    Data Table( "2013-05-02_18-35-26_peaks" ),
    Data Table( "2013-05-02_18-35-09_peaks" ),
    Output Table( "All Peak Tables" )
current data table("All Peak Tables");
Graph Builder(
    Size( 574, 500 ),
    Show Control Panel( 0 ),
    Variables( X( :Adj Time ), Y( :Name( "C-2-C" ) ), Overlay( :Dataset ) ),
    Elements(
        Points( X, Y, Legend( 1 ) ),
        Line( X, Y, Legend( 3 ), Row order( 0 ), Summary Statistic( "Mean" ) )
        Dispatch(
            "400",
            ScaleBox,
            {Legend Model(
                1,
                Base( 0, 3, 0 ),
                Base( 1, 3, 1 ),
                Base( 2, 3, 2 ),
                Base( 3, 3, 3 )
        Dispatch( {}, "Graph Builder", FrameBox, {Marker Size( 3 )} )
Graph Builder(
    Size( 607, 500 ),
    Variables( X( :Adj Time ), Y( :Height ), Overlay( :Dataset ) ),
    Elements(
        Line( X, Y, Legend( 4 ), Row order( 0 ), Summary Statistic( "Mean" ) )
        Dispatch(
            "Height",
            ScaleBox,
            {Min( 2302059.49656751 ), Max( 14000000 ), Inc( 2000000 ),
            Minor Ticks( 1 )}
        Dispatch(
            "400",
            ScaleBox,
            {Legend Model(
                1,
                Base( 0, 4, 0 ),
                Base( 1, 4, 1 ),
                Base( 2, 4, 2 ),
                Base( 3, 4, 3 )
maarten
Jun 18, 2013
Woke up with a simple idea that works
  • Create a dummy table with time (0 to 1200 with 0.125 intervals).
  • join this table with any of the runs, one at a time.
Below picture is an plot using the graph builder - it indeed suggests there might be a pattern.
