BookmarkSubscribeRSS Feed
mark_a_h
Community Member
Aug 20, 2014
Overlay Plot legend direction question
In the Overlay Plot, my "Groups" entries are laid out horizontally.  How can I get them to lay out vertically (as JMP8 did)?
Okay.  A little more information would be helpful.  I have "Overlay Groups" enabled; consequenty, I get a legend that comes out horizontally under each plot.  It is the legend for each Overlay Plot that I would change the direction.  I thought that I ran across the control to do this, but I can not find it now.
David_Burnham
Jul 13, 2011
Re: Overlay Plot legend direction question
I've just created an overlay plot and my groups are aligned vertically.  However, there are a couple of options that will influence the layout - from the red triangle hotspot "Ungroup Plots" and "Arrange Plots".  You have a good memory if you can recall how JMP 8 behaved!
Dave
-Dave
