BookmarkSubscribeRSS Feed
natalie_
Jan 6, 2016
Overlay Plot Scripts
Hi all,
I have a quest about changing the scripts of an overlay plot.  Say I have a for loop that creates a new plot on each iteration.  Each iteration updates a string variable which is the name of the next column to plot.
What syntax do I use to change the column?  I copied the script from an overlay plot that I made.   Instead of using :Name("0V"), I tried using :AsColumn(xCol), but I had no luck.  Any suggestions?
for(k=2, k<=2, k++,
  xCol = Column(dtSummary, k);
  yCol = Column(dtSummary, k+65);
  ov = dtSummary << (Overlay Plot( X( :Name( "0V" ) ), Y( :RP_0V ), Sort X( 0 ), Separate Axes( 1 ) ))
pmroz
Jun 23, 2011
Solution
Re: Overlay Plot Scripts
This approach will work.  Use a table variable and the column(<table>, <column-name>) construct:
dt = open("$sample_data\Car Physical Data.jmp");
xcol = "Turning Circle";
ycol = "Weight";
Overlay Plot( X( column(dt, xcol) ), Y( column(dt, ycol) ), Separate Axes( 1 ) );
natalie_
Jan 6, 2016
I changed my code so that it wouldn't have :Name, but still, no luck getting it to work.
for(k=2, k<=2, k++,
  xCol = "_"||Char((k-2)*10)||"V";
  Overlay Plot( X( :_0V ), Y( :RP_0V ), Sort X( 0 ), Separate Axes( 1 ) )
pmroz
Jun 23, 2011
Solution
ycol = "Weight";
natalie_
Jan 6, 2016
Thank you very much!
