  • Due to inclement weather, JMP support response times may be slower than usual during the week of January 26.
    To submit a request for support, please send email to support@jmp.com.
    We appreciate your patience at this time.
Level XIII
Outlier (👽) screening with Jmp Dashboards - how?
I want to do some Outlier screening by listing the aliens in my class.
First attempt:  Local Data Filter
I was quite shocked with all the aliens in Big Class!
... but then I noticed that the data filter was just ignored (because on day 1 there were no aliens in the class - and with no matching rows, the Data Filter is just reset - instead of showing 0 matching rows !!!).
This seems to be related to Data filter: how to specify the limits :
If a value is just used in the data filter but not in the data table, it is removed from the data filer.
This behavior interferes with another behavior of Jmp: if the last filter value is deselected, all rows get selected (instead of none).
So, with the current behavior of Data Filters, this approach doesn't work :(
Next, I used a Where() clause to restrict the Tabulate Report.
Unfortunately, if one day there are no aliens in the class, the Where clause produces an error message - instead of restricting the data set to 0 rows:
This Where-clause for data table 'Big Class' resulted in no rows: :alien == 1
List of "aliens" for the 4 cases:
Please note:
For the case with Where(), there is another issue:
The row selection for the report is static.
After XX changed to non-alien - he is still listed in the report:
dt << New Column( "alien", nominal, set each value( 0 ) );
myDashboard = Function( {myTitle, withWhereClause},
	New Window( myTitle,
		<<Show Menu( 0 ),
		<<ShowToolbars( 0 ),
		Tab Box(
			Tab Page Box(
				"aliens",
				Eval(
					Substitute(
							Expr(
								Tabulate(
									Add Table( Row Table( Grouping Columns( :sex, :age, :name ) ) ),
									__selectAliens__
						Expr( __selectAliens__ ),
							If( withWhereClause,
								Expr( Where( :alien == 1 ) ),
								Expr(
									Local Data Filter( Close Outline( 1 ), Add Filter( columns( :alien ), Where( :alien == 1 ) ) )
			Tab Page Box(
				"all Students",
				Tabulate( Show Control Panel( 0 ), Add Table( Row Table( Grouping Columns( :sex, :age, :name ) ) ) )
// 1) Data Filter --> so many aliens ?!?! no, Data filter was ignored (filter is OK, see below)
myDashboard( "1) Data Filter, no alien", 0 );
// 2) Where Cause  + no matching row --> error message instead of a report
myDashboard( "2) Where(), no alien", 1 );
dt << add rows( {name = "XX", alien = 1, sex = "M", age = 200} );
// 3) Data Filter + 1 alien
myDashboard( "3) Data filter, 1 alien", 0 ); // new test: --> filter OK --> works
myDashboard( "4) Where(), 1->0 aliens ...", 1 ); // Where Clause  + matching row --> dashboard is created, but ...
// XX gets human -> Dashboard  #4  stays the same :(
//dt[41, {"alien"}] = 0;
18 REPLIES 18
Re: Outlier screening with Jmp Dashboards - how?
Have you made sure your brackets are where they should be?
Level XIII
@jthi , right.
I corrected the code
... and added screenshots how the lists of aliens look on my system for the different cases.
Depending on what you wish to do in the end you do have some possible workarounds:
  • Add "blank" row with :alien = 1 (all other values missing except for the alien being 1)
  • Create custom filter using List Box (or something else) and then you can have your own logic and options
  • Use some sort of inverse filter if no ones are found
  • Use different view if no ones are found
  • Don't hide data filter to make it more obvious what is being filtered (or not being filtered in this case)
Level XIII
Level XIII
Is it a workaround to show the user that there is an issue in Jmp - I want the user to work with Jmp without seeing issues :)
Concerning the other workarounds:
I don't like it to reinvent the wheel (create my own Data Filter) - just to prevent Jmp from "doing something wrong".
So what remains is option # 1:
add dummy rows to the data table such that the Data Filter doesn't get cleared by not finding any matching rows.
with some nasty disadvantages: the dummy rows have to be "removed" manually everywhere else...
  1. Col Number (if(:dummy_row, ., :alien), ...);
  2. Graph Builder (..., Where(Ismissing(:dummy_row));
  3. dfRows = myDataFilter << Get Filtered Rows;
    NRowsAfterDummyScreening=NItems(Loc(-dt[dfRows,"dummy"]+1));
And it will just work as long as the user doesn't activate
Include missing for grouping columns( 1 ).
For future versions of Jmp, I hope that there will be an option to prevent the Data Filter from resetting when no matches are found. Here is the wish:
Local Data Filter: option to adjust to current data
Level XIII
Some insights why the approach via Where() is not dynamic
Using Where() to filter down analysis creates new linked private data table :
a private subset of the data table is generated
Level XIII
I found a way to tackle the issue with the
Use a Data filter with alien = 1 and dummy = 0 - and in addition set Count Excluded rows(1) [the default].
Then the data filter won't notice that for many age groups there are no rows with alien=1 and dummy=0.
Since it doesn't notice, it doesn't reset the selection :)
Names Default to Here(1);
	dt << New Column( "dummy", Nominal );
	dt << New Column( "alien", Nominal );
For( myAge = 12, myAge <= 17, myAge++,
	dt << add rows( {:name = "xxx", :age = myAge, :dummy = 1, :alien = 1} )
:alien[12]=1;
:sex[12]="";
:alien[39]=1;
New Window( "Outlier Screening",
	Data Filter Context Box(
		H List Box(
			dt << Data Filter(
		Local,
				Add Filter( columns( :age ), Where( :age == 13 ), Display( :age, N Items( 6 ) ) )
			dt << Tabulate(
				Include missing for grouping columns( 1 ),
				Add Table(Row Table( Grouping Columns( :name, :sex ) ) ),
				Local Data Filter(
					Close Outline( 1 ),
					Mode( Show( 0 ) ),
					//Count Excluded Rows( 0 ),
					Add Filter( columns( :dummy, :alien ), Where( Is Missing( :dummy ) ), Where( :alien == 1 ) )
NB: This solution will fail *) if one day there is not a single alien in the whole data set.
For this case ...
  1. one could hide an additional alien with dummy = 0 in a dummy age group ("-99")
    ... and take care that nobody counts the non-dummy aliens for the whole class
  2. or:  split the data filter into two:
    then both of them get enough matching rows so that they don't reset.
View more...
:sex[12] = "";
New Window( "Outlier Screening with worarounds",
		H List Box(
			dt << Data Filter( Local, Add Filter( columns( :age ), Where( :age == 13 ), Display( :age, N Items( 6 ) ) ) ),
				H List Box(
					dt << Data Filter( Local, Add Filter( columns( :dummy ), Where( Is Missing( :dummy ) ), Display( :age, N Items( 6 ) ) ) ),
					dt << Tabulate(
						Add Table( Row Table( Grouping Columns( :name, :sex ) ) ),
						Local Data Filter( Close Outline( 1 ), Mode( Show( 0 ) ), Add Filter( columns( :alien ), Where( :alien == 1 ) ) )
Level XIII
... with a quite surprising result.
According to the data filter and the subtitle, Tabulate should list aliens - but in the list are all rows with the respective age, independent of the values in column alien and dummy.
		H List Box(
			dt << Data Filter(
				Local,
			dt << Tabulate(
				Add Table(Row Table( Grouping Columns( :name, :sex, :dummy, alien ) ) ),
				Local Data Filter(
					Close Outline( 1 ),
					Mode( Show( 0 ) ),
Level XIII
I prepared this script for internal discussions about Outlier Screening in Jmp.
It shows most of the aspects and can be used as a starting point for further development of workarounds ...
:alien[12] = 1;
:sex[12] = "";
:alien[39] = 1;
New Window( "alien screeing",
		<<Show Menu( 0 ),
	H List Box(
		V List Box(
			Button Box( "shuffle",
				students = Loc( dt[0, "dummy"], . );
				dt[students, "alien"] = J( N Items( students ), 1, If( Random Integer( 100 ) < 5, 1, . ) );
			Button Box( "no aliens today",
				dt[students, "alien"] = J( N Items( students ), 1, . );
			Button Box( "- 1 student", dt << Select Rows( Random Integer( N Rows( Current Data Table() ) ) ) << Delete Rows ),
			Button Box( "- Linda",  dt << Select Rows( Loc(dt[0,"name"],"LINDA") ) << Delete Rows  ),
			Button Box( "add dummys",
			Button Box( "remove dummys", dt << Select Rows( Loc( dt[0, "alien"] ) ) << Delete Rows ),
			Tabulate(
				Add Table( Row Table( Grouping Columns( :dummy, :name, :age, :sex, :alien ) ) )
		V List Box(
				Panel Box( "my subset",
					<<Background color( -12040119 ),
					H List Box(
						dt << Data Filter( Local, Add Filter( columns( :age, :sex ), Where( :age == 17 ) ) ),
						dt << Graph Builder(
							title( "students/age" ),
							Size( 300, 300 ),
							Show Legend( 0 ),
							Fit to Window,
							Variables( X( :age ) ),
							Elements( Bar( X, Legend( 7 ), Bar Style( "Stacked" ), Summary Statistic( "N" ) ) ),
							Local Data Filter(Count Excluded Rows( 0 ), Add Filter( columns( :dummy ) ) ),
							SendToReport( Dispatch( {}, "", ScaleBox, {Min( 0 ), Max( 15 ), Inc( 1 ), Minor Ticks( 0 )} ) )
						dt << Tabulate(
							Title( "Aliens in the subset" ),
							Add Table( Row Table( Grouping Columns( :alien, :age, :name ) ) ),
							Local Data Filter(Count Excluded Rows( 0 ), Add Filter( columns( :alien ), Where( :alien == 1 ) ) )
				title( "all my aliens" ),
				Size( 700, 350 ),
				Show Legend( 0 ),
				Elements( Bar( X, Legend( 7 ), Summary Statistic( "N" ) ) ),
				Local Data Filter( Add Filter( columns( :alien, :dummy ), Where( :alien == 1 ) ) )
				title( "all students" ),
				Size( 700, 350 ),
				Show Legend( 0 ),
				Local Data Filter( Add Filter( columns( :dummy ) ) )
	<<OnClose( Close( dt, NoSave ) )
