BookmarkSubscribeRSS Feed
anne_sa
Feb 24, 2016
Ordinal variable used as random effect
Hello everyone,
I was trying to build a model with a random effect which is an ordinal variable.
However I got the following alert:
Does it mean that it is impossible to choose an ordinal variable for a random effect or is my variable an exception?
Thanks in advance for your answers.
jiancao
Jul 7, 2014
Solution
Re: Ordinal variable used as random effect
No, it does not take an ordinal variable as an random effect; it only accepts a nominal variable as a random effect.  (The Random Effects tab in Mixed Model personality is used to specify a variance component model or random coefficients model, while Attributes> Random Effect available in Standard Least Squares personality supports variance component models only.)
jiancao
Jul 7, 2014
Solution
anne_sa
Feb 24, 2016
Hello jiancao,
Sorry for the delay and thank you for your answer.
So I am gonna transform my variable before use it as a random effect.
Thanks again.
