Jackie_
Optimize the loop
I have some JSL code that takes a long time to execute for larger datasets.
The code runs a for loop within a for loop to calculate the mean offset by strips. I’m looking for a faster way of doing this.
Is there a way to make the processing faster? The current script takes ~20 mins to complete the loop
Here's the script below:
dt1 =Data table( "Reference data table.jmp" );
dt2 = Current data table(); /// Select Data table.jmp
Col_List1 = dt2 << Get Column Names( "String" );
For( c = 1, c <= N Col( dt2 ) -1, c++,
	theMatrix = [];
	name = Column( Col_List1[c] ) << Get name;
	if (Contains( Col_List1[c], "Currents" )| Contains( Col_List1[c], "Voltage" )| Contains( Col_List1[c], "Resistance" ),
	For( r = 1, r <= N Rows( dt2 ), r++,
		mean = dt1:Mean[dt1 << Get Rows Where( :Tests == name )];
		measure = mean - Col Mean( If( dt2:Strips == dt2:Strips[r], Column( dt2, c ), . ) );
		theMatrix = theMatrix || Column( dt2, c )[r] + measure;
	Column( dt2, c ) << Set Values( theMatrix );
Re: Optimize the loop
The 2 places I see issues, are the
and
Here is a work around for the issues  Check them out and see if the answers are correct
start=today();
For(i=1,i<=nrows(dt1),i++,
	theTest = dt1:Tests[i];
	try(column(dt2,theTest) << set property("TheMean", dt1:mean[i]));
	theMatrix = [];
	//For( r = 1, r <= N Rows( dt2 ), r++,
	For Each Row( r=row();
		//mean = dt1:Mean[dt1 << Get Rows Where( :Tests == name )];
		mean = column(dt2,col_list1[c]) << get property("theMean");
		//measure = mean - Col Mean( If( dt2:Strips == dt2:Strips[r], Column( dt2, c ), . ) );
		measure = mean - Col Mean(as Column( dt2, c ),:Strips);
show((start-today())/60);
I modified your code to bypass the processing if the Column Property "theMean" had not been set
start = Today();
dt1 = Data Table( "Reference data table.jmp" );
dt2 = Current Data Table(); /// Select Data table.jmp
For( i = 1, i <= N Rows( dt1 ), i++,
	Try( Column( dt2, theTest ) << set property( "TheMean", dt1:mean[i] ) );
For( c = 1, c <= N Col( dt2 ) - 1, c++,
	theMatrix = [];
	If( Contains( Col_List1[c], "Currents" ) | Contains( Col_List1[c], "Voltage" ) | Contains( Col_List1[c], "Resistance" ),
		mean = .;
		Try( mean = Column( dt2, col_list1[c] ) << get property( "theMean" ) );
		// Don't process if a value for theMean does not exist
		If( Is Missing( mean ) == 0,
			For Each Row(
				r = Row();
				measure = mean - Col Mean( As Column( dt2, c ), :Strips );
Show( (start - Today()) / 60 );
6 REPLIES 6
and
start=today();
	theMatrix = [];
Jackie_
Thank Jim. It works like charm
Jackie_
Hi @txnelson,
There's some issue in the logic that you suggested. If the reference data table doesn't contain the test that are in the main data table, it will delete the row values from those tests. I only to offset the test that are in the reference data table. Any help would be much appreciated
I have attached the data tables below. I only want to offset the tests that are specified in the reference table
start = Today();
	theMatrix = [];
		mean = .;
			For Each Row(
				r = Row();
Jackie_
Thanks a lot Jim.
ErraticAttack
@Jackie_ , I'm not sure what the conditional dt2:Strips == dt2Strips[r] is supposed to resolve to, but it is probably not doing what you want it to do.
Without any test data to test on, here is how I would start optimizing this -- the main one is to take the dt1 << Get Rows Where( :Tests == name ) outside of the loop.
Names Default to Here( 1 );
dt1 = Data Table( "Reference Data Table.jmp" );
col list1 = dt2 << Get Column Names( "String" );
Summation( c = 1, N Col( dt2 ) - 1,  //summation is faster that For() if you don't need to use Break() or Continue()
	values = [];
	name = Column( dt2, c ) << Get Name;
	If( Contains( name, "Currents" ) | Contains( name, "Voltage" ) | Contains( name, "Resistance" ),
		rows = dt1 << Get Rows Where( :tests == name );		// As Constant() prevents JMP from doing a lookup per row
		col = Column( dt2, c );
		col mean = Col Mean( col );
		For Each Row( dt2,
			mean = dt1:Mean[rows];
			measure = mean - If( dt2:Strips == dt2:Strips /* always true */, col mean, 0 );
			values |/= col[] + measure 	// append value to
		col << Set Values( values )
	0	// summation needs to end in a numeric
Jordan
