BookmarkSubscribeRSS Feed
natalie_
Opening files not supported by JMP
Hi everyone,
I need to open .wat files.  I am able to manually import it into a data table, and I do this by using delimited fields with Space and Spaces.  I can copy script:
Add Properties to Table(
  {New Script(
  "Source",
  Open(
  "C:\Users\user\Downloads\B8A17901.WAT",
  columns(
  Column( "Column 1", Numeric, "Continuous", Format( "Best", 10 ) ),
  Column( "W.A.T.", Character, "Nominal" ),
  Column( "DATA", Character, "Nominal" ),
  Column( "ATTACHED", Character, "Nominal" ),
  Column( "c000005", Character, "Nominal" ),
  Column( "c000006", Character, "Nominal" ),
  Column( "c000007", Character, "Nominal" ),
  Column( "c000008", Character, "Nominal" ),
  Column( "c000009", Character, "Nominal" ),
  Column( "c0000010", Character, "Nominal" ),
  Column( "c0000011", Character, "Nominal" ),
  Column( "c0000012", Character, "Nominal" ),
  Column( "c0000013", Character, "Nominal" )
  Import Settings(
  End Of Line( CRLF, CR, LF ),
  End Of Field( Spaces, Space, CSV( 0 ) ),
  Strip Quotes( 1 ),
  Scan Whole File( 1 ),
  CompressNumericColumns( 0 ),
  CompressAllowListCheck( 0 ),
  Labels( 1 ),
  Column Names Start( 1 ),
  Data Starts( 2 ),
  Lines To Read( "All" ),
  Year Rule( "20xx" )
But what I really want to do is write a script that does this, but I am not sure what it is I am doing wrong.  I am selecting a file, creating a new data table and adding properties to that data table.  Any ideas?  Thanks!
file = Pick File();
dt=New Table();
dt << Add Properties to Table(
  {New Script(
  "Source",
  Open(
  file,
  columns(
  Import Settings(
  Strip Quotes( 1 ),
  Labels( 1 ),
  Data Starts( 2 ),
  Year Rule( "20xx" )
ms
Super User ms
Re: Opening files not supported by JMP
You do not need a table property to do this. A new table is created automatically by Open().
file = Pick File();
dt = Open(file, ...);
ms
Super User ms
file = Pick File();
msharp
And the Russians used a pencil.
To expand on MS's answer.  Open() takes a wide variety of options and delimitation can be specified in every way imaginable.  For more information Search Open in the Scripting Index.  Example 2 will probably be most beneficial.
Of course since you already have all the open properties specified from the script above.  Just delete this portion of your code:
dt=New Table();
  {New Script(
  "Source",
and the subsequent ")})" that goes with it.
Of course, I'm pretty sure you could optimize the code, I doubt there's a need to specify the columns.
natalie_
Thank you, I didn't realize it would be that simple.
natalie_
Thank you!  I thought I had to add the properties for some reason.  It is way simpler this way.
file = Pick File();
dt = Open(file,
  Import Settings(
  Strip Quotes( 1 ),
  Labels( 1 ),
  Data Starts( 2 ),
  Year Rule( "20xx" )
