BookmarkSubscribeRSS Feed
hpatino4367
Community Member
Opening SAS dataset offline and how tse SAS Variable Names for Column Names
The user guide is clear on how to use variable names using the dialog box or SAS server  instead of variable labels.
However, i want to do the same but using JSL.
sasfile=Open( "mypath/myfile.sas7bdat");
Any parameter to use?
with the labels I get for some datasets error when exporting the file as "xlsb" using JSL
